- Jan 12, 2001
- Kansas, USA
I spent half the holiday weekend benchmarking. I chased a world record (I'm currently ranked #4 globally in the PCmark10 benchmark). I upped the voltage and booted up at 5.3 gig (had been benching at 5.2). I was only 120 points away from winning when my temp alarm went off. The computer finished the benchmark, but I had a much lower score than expected. I'm sure it thermal throttled. Now, if I try to OC more than 5.0 GHz and add more then 1.25v, I get a huge spike in temp under load.
At first I blamed my watercooling loop, but now I think the CPU needs to be delidded. I probably cooked off the what little bit of the crappy TIM that Intel had on there. I've been googling and searching. The Kaby Lake-X is not soldered (nor is Skylake-X). I have a delid tool, but have determined it will not work on socket 2066 X-series CPUs because they're too big.
So, I don't know what to do. Buy the special socket 2066 delid tool that I'll probably only use once (if it's even available) or try to delid it the old fashion way or leave it alone and maybe step up to the 8-core 7820X CPU with more PCIe lanes and quad channel memory (and will probably need to be delidded too)?
