diehrd said:Just Downloaded And Edited The Dual Client And Norton Found A Virus In It ... Watch Out People
It is a false positive... it's just like McAfee finding HijackThis as some sort of worm.diehrd said:Just Downloaded And Edited The Dual Client And Norton Found A Virus In It ... Watch Out People
I'll take a look at the installer later today. Thanks for the insight and help!Kto said:Hi.
I have trouble when using "Ultimate FAH Network Installer".
When service is registered in WinXP|Win2k Srv ("sc" command), registry key "HKLM\System\CurrentControlSet\Services\FAH\Parameters" isn't created. But "regini.exe" can't create keys. So, this key isn't filled and service don't start properly. Service stops direct after starting. It shows error sometimes.
To solve the problem I inserted before "regini.exe..." in single_install.cmd next command "reg add \\%1\HKLM\System\CurrentControlSet\Services\FAH\Parameters".
But it's needed running under admin's account directly. I had to use "runas" command to run "single_install.cmd". It's not comfortable.
I always glad to help.dark_15 said:Thanks for the insight and help!
Certainly.dark_15 said:This installer does need to be run under an admin since it is copying files and modifying the registry of remote computers. You wouldn't want regular users to accidentally able to do that, right?
The other reason is it requires if someone wanted to borg F@H to other workstations maliciously.
BenF said:Hi, I have a few questions about the Ultimate FAH network installer.
I'm hoping to convinse my school's it Professional into letting me install F@H on our school's network. I don't think most schools would alow this, but my school cares alot about the environment, helping others and making the world a better place. B/c they have that attitude, I think I can get them to let me install it.
Anyway, on to my questions. First of all, the computers get shutdown afterschol and are then turned on again when school starts, how would that effect F@H? Do you need to shut down the service before shutting down the computers for the WU progress to be saved? Also, is there a way to have all the F@H Logs on a single server computer, or do they need to be on the individual computers? Which way would be work better/be easier to set up?
Hopefully if I can get all the questions I have come up with sorted (I beleive I will have more, but these are the first one I have though of.), I will be able to add 30+ 3.0ghz p4s to team 32.
BenF
BenF said:ok, thanks. So with that installer, I get set up the configs (with my username of course, and team 32) and let the admin run it.
