Adak said:If you have a dual-core cpu (or more), then the FAH client to run for best results would be a version of the SMP client. It generates 4 threads but produces the fastest WU finisher, as well as earning the most points, by far.
Within the SMP family of clients, the Linux one is currently the most stable, fastest, and highest point getter. It needs a 64 bit version of linux, and just browsing the internet and such is a breeze, even for noobs at it. Highly recommended for dedicated folders with dual core cpu's.
Windows SMP client is next - newest and not quite as stable as the Linux version, but a real advantage still, over folding two versions of the uniprocessor FAH client (like the 5.04, etc.).
Following the install instructions CAREFULLY (especially on setting up the administrator's account before installing), is very important.
A third choice is to run the linux client in VMWare software, over Windows. Works well, but about 12% slower than native Linux, and needs 2gigs of RAM for reasonable multi-tasking. A bit more complex, but VMWare is available free.
All the above have detailed install guides.
Just let us know which one you want to install, and whatever questions you have.
s[H]sIkuA said:Thanks for the reply , going to try the SMP for Windows now One more question, if the service is running on the background , what happen if I open back the folding console?
pscout said:When you say it is running in the background, I assume you mean it is minimized? If so, there is no effect on it ... it just makes it viewable when you display its window. Running this way the only thing you can do with it is ctrl-c which is the proper way to shut it down.
If you meant by running in the background that you configured it to run as a service, then the console is not viewable. You can open the log file to see what it is doing, or use fahmon which also has a convenient view to display the console's log. The fahlog.txt file caintains everything the is displayed on the console.
Papo said:most of them are dualies but probly can't handle -advmethods
I scimed throug the post my antivirus program thinks its a trogen virues in the file? let it go or wait i would love to help just dont want to mess up or have to format thanks
