- Dec 5, 2001
- Canuckistan
I recently had a question asked that I thought would be most beneficial in the forums.
I thought i had an answer to his question, but when i worked it out, my theory didn't work. Started to contradict some of what i was saying. So i'll state where i had a problem also.
When i was calculating where the heat would increase, i had thought that an increase in voltage would cause a larger amperage draw. But that isn't true since voltage and amperage are inverly proportional to each other. If this is so, then increasing the voltage should decraease the amperage for a given wattage.
Or am i wrong in presuming that the wattage ncessary for a CPU is dictated by the amount of work it's doing, and not directly effected by what the voltage is set at?
A great question, any takers?
I just read that post about "basics of overclocking out of intrest. One little question that has been bugging me for quite a long time: the voltage (vcore, etc)- is heat the only thing that limits it? Because i thought, having something with very high voltage going through it would surely blow the circuit? I.e. if heat wasn't a problem, could you have the processor running at like 80v or something, or would it just blow the electric paths?
