- Aug 30, 2004
- Santa Barbara, CA
- Thread Starter
- #41
Bandwidth screenies. Not bad huh?
Super Nade said:Tref 1168 (166MHz, 7.8us)
g0dM@n said:How is that 166mhz? I thought that the cycle time is 7.8 * (freq). 166*7=1295... in any case, why would it be set to 166 when that ram is rated ddr400~ddr533, and also you're running it at 300mhz 1:1... I'm confused as to how you came up with that cycle time. Care to explain?
Nice, btw... I had the same stuff until I sold it.
Dread-Star said:NEW SAN DIEGO SETTINGS!
Note: I am still working with this SD 4000, so these settings are in no way final. Think of them as Beta settings.
Last Update 5-22-05 increased OC to 2.78 278x10
These settings are 24+hr Prime95 , 3Dmark, and Memtest stable. Plus many hrs gaming etc.
MB: DFI Lanparty UT NF4 Ultra D Rev.A3
Bios: 310p
CPU: SD 4000+ CABGE 0515 VPMW @2.78 Idle>29c Load>39c-42c Ambient 68f w/ Swiftech H20-120 3A WC
VC: ATI X850XT PE w/ATI 6.14.10.6525 drivers (CAT 5.4)
OS: Windows XP Home w/SP2
Ram: Corsair Twinx1024 XMS 4400 DDR550 C25PT #4404 Ver. 1.1 (TCCD) In the #2 and #4 (Orange) Dimm slots
Chipset Drivers: Revision 6.39 (w/out IDE or Firewall Drivers)
Current Ram Settings : Corsair Twinx 4400 DDR550 C25PT w/437 TCCD. This 4000 SD will run these high speeds alright but if I tighten up the timings it starts to become unstable in Windows and will fail Prime instantly.
Dram: 200mghz 1:1 (1:1 w/ CPU clock set at 278 x 10 DDR556)
CPC: Enabled< This setting does not show on the 310p bios w/t SD Chip and it is always 1T
Tcl: 2.5
Trcd: 4
Tras: 8
Trp: 4
Trc: 11
Trfc: 16
Trrd: 2
Twr: 2
Twrt: 2
Trwt: 2
Tref: 3120
Twcl: 1
Bank int.: Enable
Skew increase
Skew control: 255 +
Drive strength: 7
Data strength: 4
Max. Async: 7ns
Read Preamble: 5ns
Idle Cycle: 256
Dyn. Counter: Enable
R/W Bypass: 16x
Bypass Max: 7x
32Bit Gran.: Disable
CPU Voltage Settings etc:
CPU: 278 x 10
CPU Vid: 1.300v
Special Control: +123% = 1.57 (Bios) 1.55 (Software)
Startup Vid: 1.55v
LDT/FSB: 3x
LDT: 1.2v
Chipset: 1.5v
VDimm: 2.9v
Vid Card: 100mghz
Cool & Quiet: disabled
PCIex Maximum Payload size: 256
DFI Logo: Disabled
3DMark2001 score @ 10x280 = 2801 1:1 32310 :http://service.futuremark.com/compare?2k1=8566476
As you can see from this 3DMark2001 score I am now GPU limited, you can tell by the Nature score ( it is the same for all settings above 2.5ghz)
@ 290x9 =2610 1:1 31122 :
http://service.futuremark.com/compare?2k1=8566588
DREAD
24/7 Stable Pic Idle & Stable Pic Load: Note the low Chipset temp, I used AS5 this is after it cured
Dread-Star said:I have also tried different bioses, currently I am using the 6-23-05 final.
This Bios is far better for my San Diego than the 310p, however I no longer have a NC core, so comparing these is not an option right now.
But, I can help with the Ram some, also if you have changed multiple Bioses and have gotten a lot of errors through testing, then a fresh install is a must!
Tref is a critical setting, try setting it using this formula 7.8 ( For Dual sticks 15.6 for single sticks of Ram) x 262 (Or any HTT VALUE) = 2043.6 find the tref value closest to this number and use that one. I got this from the XS forum and it really helped to stabilize my OC. Here check out the results from using the 6-23-05 Bios and a fresh install of XP Pro.
Bios: 6-23-3 Final
CPU: SD 4000+ CABGE 0515 VPMW @250x12=3000mghz
VC: ATI X850XT PE w/CAT 5.7
OS: Windows XP Pro w/SP2
Chipset Drivers: Revision 6.53 (w/out IDE or Firewall Drivers)
Dram: 200mghz 1:1 (1:1 w/ CPU clock set at 250 x 12 )
CPC: Enabled
Tcl: 2.5
Trcd: 3
Tras: 6
Trp: 3
Trc: 7
Trfc: 15
Trrd: 2
Twr: 2
Twtr: 2
Trwt: 2
Tref: 2048
Twcl: 1
Bank int.: Enable
Skew control: Auto
Skew Value: 0
Drive strength: 7
Data strength: 2
Max. Async: 7ns
Dram Response Time: Normal
Read Preamble: 5.5
Idle Cycle: 256
Dyn. Counter: Disable
R/W Bypass: 16x
Bypass Max: 7x
CPU: 250 x 12 = 3000mghz
CPU Vid: 1.35v
Special Control: +133% = 1.71v in Software
Startup Vid: 1.55v
LDT/FSB: 3x
LDT: 1.2v
Chipset: 1.5v
VDimm: 2.9v
Vid Card: 100mghz
DFI Logo: Disabled
Good Luck!
DREAD
3000mghz Sandra : 3000mghz CPU-z Certified : 3000mghz Smart Guardian
_________________________________________________________________
Dread-Star said:Most peeps are using this thread for reference Only.
It would be a shame to un-sticky it.
