i was thinking about hooking up a 12v capacitor (like one from walmart for subwoofer amps) in line with the 8pin gpu plug. ive used them with solar pannels and such and they def help a bunch.
ive got a few hard drives and such drowing a lot of power. i also have a secondary gpu i use for linux, and im trying to avoid buying a psu whil also having a capacitor in my computer because that would impress my friends and be badass imo.
im just worried about things like wire gauge and if the extra energy would damage any components at idle or something. any one got any advice (and by advice i dont mean "dont do it" lol if you have a reason i shouldint pleas give a little bit of detail so i can google)
id probably by a fuse and i was thinking of ordering some high amp diodes? i have a pi in my rig( to control leds and such) in case i need to like detect shutdown and trigger a relay or something. im willing to put work into this to make it work, as long as it shows results ( i get a throttle cap reason: pwr or whatever in gpuz constantly)
