- Nov 10, 2012
- Ankeny Iowa
Reconfigured my loop setup and added a temp probe to the reservoir. Loop temps run about 20C at idle and after 60 mins of R23 max temp is 26C water temp
I am running a 480mm x 60mm rad with 18 fpi in push/pull configuration with a Ryzen 9 7900x. Fans are set up on a fan curve based off the temp probe. Min fan speed is 20% @20C and ramps up to 60% @ 50C, fans don't go much over 35 to 40% after 60 mins of 100% load. CPU clocks stay steady at 5.4 all cores. Thinking of adding a 6950XT to the loop and was going to add more radiators but it seems like I don't need to? Any advice on setting up fan curves or loop temps?
