- Mar 13, 2012
Hi Peoples
I have an existing water cooling setup that has suddenly dropped in performance just with the video card cooling . My GTX480 used to idle at about 50 degrees but has gradually risen up to 70 and is staying there. Still better than the idle temp of 75 with the stock air cooling (I know, its a dog of a video card for heat) but still the cooling should be working a lot better.
The water cooling was obviously working, been that way for a couple of years but something has changed and I don't know what. I took apart my water loop and got rid of the old coolant 3 days ago, used some distilled water to push out the old coolant with my mouth. Put it back together with better joins, 1 less slightly kinked section, some shortened sections and all fresh coolant but the temp is still sitting at 70 idle. CPU is fine, idles at 45-50 depending on the weather, that hasn't changed.
By guesswork I have narrowed it down to a possible radiator blockage or perhaps the pump has weakened. While messing around with the loop from time to time I have started the machine with only the reservoir full of coolant which quickly drains. I switch the computer off as soon as I hear the pump trying to push air, could this damage the pump in just that short moment?
A third possibility is that the video card is faulty and generating more heat somehow but this seems far less likely. The computer is stable and I can still run games for a couple of minutes until the video temp gets over 100 and I have to quit the game.
Any ideas what is the likely culprit here? or ways to find out? I'm looking at buying a flow meter and I have no problem buying a new pump, the one I have now is the MCP355.
Cheers
Cheers
