- Dec 7, 2011
- glasgow scotland
Double post
Surely all them 90° fittings cant be good for your single pump?
pressure seems ok and temps are same as before . but im thinking of going for a bigger case its a bit tight anyone know any good cases for watercooling
Corsair 800D is pretty much the de-facto H2O case.pressure seems ok and temps are same as before . but im thinking of going for a bigger case its a bit tight anyone know any good cases for watercooling
How did you measure pressure? Did you derive it from flow measurements, pump RPMs/current or actually directly measured pressure?
I think a relevant question would be why you used them in the first place when so many of the turns could have been taken with either one 90° fitting or none at all? That's a lot of restriction for no real benefit.
Whats the absolute best tubing for a WC system?
