FEATURED The Water-Cooled System picture thread!
Status
Not open for further replies.
Here is my build so far
Here is my first build with water. Got my FX-8120 and was getting up to 70c on all stock settings so had to get some thing other then stock HSF. So I got Water.
Now My Temps are never above 50c.
Then tryed some overclocking for kicks.
Tell me what you think.
Cpu FX8120
Mother Board Gigabyte GA-990FXA-UD3
Ram Mushkin Silverline 8GB (2x4GB) DDR3 1333MHz CL9
SSD Boot Drive Corsair Force Series 3 90GB
Hard Drive Seagate 1TB
OCZ StealthXStream 2 Ultra-Quiet 600W
Sapphire HD 6870
No Room still have to make a bracket and cut window in side panal. SSD is on other side.
HTPC :)
Hi guys,
first post in this forum "showing off" my newly built watercooled HTPC. its a i5 2500k overclocked to 4.5 and an EVGA GTX570 SC. Rad is a single XSPC RX240 with 4 500rpm fans (2 pull, 2 push). Its mainly used to watching live TV, but i play over the weekend.
cheers
Thats the original case
Thats my case after i cut all the walls and made some holes (for the cable management later)
And this is the final result
screenshot of the temps
Status
