Gskill trydent z 7200 2x24 problem to get it stable at 7200
I think I just get better than that getting a better aio, stupid me trying to making a full msi setup.
I wouldnt bet on it... the difference between most 360mm aios is only a few C and that's not going to prevent throttling.
Also note, CB is a VERY heavy load. Unless you're rendering like that, temps won't be close (in gaming, for example).
I’ll try then re apply thermal paste, do u have some to recommendation?
I did -0.09 undervolt and voltage to 1320, limited PL1 and PL2 to 288w, p-core all 5.7, e-core 4.5 and ring 4.8. Still 37k. I’m seeing ppl with cooler box hitting 42k +. Idk what I’m doing wrong.
I'd don't think you're doing anything wrong... what are they doing to reach 44k. You're about right...
So, I just ran CB on a 255W 14900K system and scored low 37K, FYI. :)
I'm imagining the boards they are running it on allow for a lot more power to go through and cooling to minimize throttling. Raise the power limit (through whatever program you want to use), don't touch the clockspeeds.
Then u saying that 37k isn’t a bad score for gaming? That I’m use my pc for. It’s hitting now 75c with any game, stable, without crash, and 7200 on xmp.
I've been saying it's fine for a while now. :)
For gaming, I wouldn't set all cores to the same speed, let it boost up to the higher clocks it's capable of. But yeah, you're getting what you can out of her.
Do u recommend then set two for 5.7 and others to 5.4?
