Hello guys, I’m starting in overclock field, trying for 3 months runs my memory at xmp 7200 but not success yet, I have this kit gskill trydent z 2x24gb 7200mts white. My setup is msi z790 edge WiFi, i9 14900k. Trying a lot of timing and voltage but always crash in games and doesn’t pass in tests. The max that I got was 6800mts stable. Could someone helps me? Thank you!
Yes I have the last bios, but after release of 14th generation only have 2 bios update. And I called to g skill that they explain for pay attention on future bios release because they tested stable for this motherboard 6800mts, that’s the last stable that I got. Idk if have any way to push beyond. And my ram is in qvl list.
Like EarthDog suggested: Did you try adding more System Agent Voltage? In order for me to run 4 sticks (4x16gb) for a total of 64gb, I ad to add more SOC voltage. It's AMD's version of System Agent Voltage. I had to add 1.2v to help the IMC (internal memory controller) on the CPU to help it along.
I haven't seen any CPU/IMC that couldn't make 7600. Even my 13600 ES can make 7600. I also haven't seen any issues with G.Skill Trident Z5 kits. The 2x24GB 7600 one that I have, worked at XMP on every motherboard that I was using it on, including AMD B650E/X670E.
In this case, I'm almost sure it's the motherboard issue or maybe only BIOS. MSI is nothing special in this generation, and they don't really care about improving their BIOS. Once they do that, motherboards can make 1-2 ratios more (mainly the last BIOS releases for Z690). This is also why they have the lowest maximum RAM in official specs. Even their top mobos haven't tuned BIOS for high-speed RAM, and MSI doesn't guarantee anything above 7800 on two slots.
You can play with additional settings, but somehow, I doubt it will help. This generation works at all auto settings for IMC and additional voltages all the way up to 8000. Problems start above that. Manual voltage adjustments help when the motherboard is undervolting. For some reason, my ASUS APEX does that.
I adjust the SA voltage to 1.435v, vidd also and dram voltage, let’s see if it’s works now, because msi did a last bios update on 24th, memory compatibility, me and microcode.
If more voltage doesn't help and default timings/voltages/XMP doesn't help, then it's either the mobo or the CPU or possibly both. Unless you can swap either one, and keeping the same memory, test to see if one of those is the culprit. This issue is with your current setup with the same memory, right?
This is a unique issue that can't be narrowed down enough without swapping out one of the major components, IE CPU or mobo.
It’s brand new parts, I can imagine that mostly bios problem since I have i9 14900k that could run high speed memory. Maybe the mobo doesn’t support yet speed above 6800mts.
Even brand new parts can be defective, trust me. My current video card was faulty right from the box and I didn't know it. I had thought it was memory or my games drive. Chasing down the problem I replaced every single part rebuilding my rig with no luck thinking it can't be my video card because it was brand new. Come to find out the last and final part I swapped out was the video card.
Once I got the replacement, everything was perfect. Don't think for a second brand new parts can't go bad, they do.
I called to g.skill and they said for this motherboard, can run only at 6800mts for I pay attention on new bios releases and test, but unfortunately still the same with the new release, at 6800 works great!
Well then, if they (Gskill) say 6800, and you tested it at 6800 and it's stable, then I guess that's all you're going to get from that set of ram. Very nice no doubt!
Finally I made it guys, I don’t know if it was my knowledge about it increase or newer release of bios, but I get it with a msi aio coreliquid 360r running at 7200mhz.
I’ll put here my bios setup for reference if someone have the same issues, running stable, without crash at max temp 75c running any game.
P core 0 and 1: 6.0
E core all 4.5
Others: 5.8
Memory try it: 7200 x 100
C lite: mode 7
Undervolt: -0.050
Setup: i9 14900k and msi edge WiFi ddr5
That’s all I can remember if someone ask I can check out. Thanks for all that support me!
Post magically merged:
One more question, I disable everything that should get some RAM memory, includes on board video, even that I get 47.7gb of memory, there are a way to get full 48gb? Or maybe the motherboard don’t allow me to full disable onboard video?
And every game are running well, without crash, stuttering or low fps. But at cinebench I get a ridiculous score, that’s a thing that I should worry about?
