- Mar 24, 2024
- California
- Thread Starter
- #81
Here is one of my old modded Playstation 1's. It is MM3 mod chipped so its region free. It is overclocked to a toggle switch, It can switch between 33mhz and 40mhz. It has been painted, paint job doesn't look that good though after a several years. I had custom Stickers made to replace the power,open,reset, and the name of the system because i painted over them.
It looks kinda like a race car with sponsers or comic book like. It is one that i just made for myself. It is just a hobby.
What makes it unique is that i have Dual 12v fans in it. 1 fan for the laser assembly and another fan for the power supply. The fans run off a tiny step up voltage converter. So i take a small voltage from the PSU and step it up to power the 2 12v fans. The power supply has been recapped using low esr capacitors so it will run cooler. The PSU plug has been flipped to make room for a fan above it. The power LED light has been changed from green to red. The console looks weird at first until you get used to the comic book look. It is painted red and black. I used to sell them but only when they came out really well unlike this one which is flawed. I almost forgot i installed a switch to spin the disc that can be turned on or off so, no haveing to close the lid to run a disc. That also gives alot more power to the laser it seems. Xstation did not exist yet, plus the laser in this unit still works. I think its a 7000 or 7501 version, not certain i would have to take it apart to look cause i did this mod years and years ago. Well i hope you like it Here are some photos. I also soldered in a memory card so it has a built in memory card.
Not going off topic to far, Anyone know much about the playstation classic. I have never had one of those, I did a couple of search's on it and came up with some specs and i read there have been some mods that have made it a pretty good device. Wondering if any of the hardware could be upgraded. Again i have a friend that can do BGA rework really well so BGA isn't something impossible to change. He doesn't work for free though, i would have to pay him for his expertise and he takes a real long time to do anything that is out of the norm, Talking months Micro Hand reballing isn't something i have ever asked him to do. So not sure if he would even do it. Everything is much faster when there is a BGA stencil for the chip.
What Socket is the CPU? Or BGA package? of the Playstation Classic
Wondering if that hardware is custom or is it standard?
Looking at the board it seems like it would be easy to pull the chip.
I could buy one then have the chip removed to find out what socket it is. If its standard then i could try something else but then the guessing game begins, an expensive guessing game i rather avoid playing. Resulted last time with a failed system, fun but failed project. Sometimes it's cool to be the first to try something. People can learn from my failure and succeed in the future. It would have been a powerful Atari VCS steam machine.
Atari VCS APU upgrade attempt
ATARI VCS apu upgrade Do not try this yourself as a disclaimer, I had mine done by a professional who does it for a living. I had my Atari VCS professionally reballed and had an a Ryzen 3 3300U soldered into it and it won't work, Witch i was prepared and knew it might not, after dumping 470 $into...
forums.atariage.com
