"pools" : [
"url" : "stratum+tcp://middlecoin.com:3333",
"user" : "BTC_Address",
"pass" : "x"
"intensity" : "18",
"vectors" : "1",
"worksize" : "256",
"kernel" : "scrypt",
"lookup-gap" : "0",
"thread-concurrency" : "0",
"shaders" : "80",
"gpu-engine" : "0-0",
"gpu-fan" : "0-85",
"gpu-memclock" : "0",
"gpu-memdiff" : "0",
"gpu-powertune" : "0",
"gpu-vddc" : "0.000",
"temp-cutoff" : "95",
"temp-overheat" : "85",
"temp-target" : "75",
"api-mcast-port" : "4028",
"api-port" : "4028",
"expiry" : "120",
"gpu-dyninterval" : "7",
"gpu-platform" : "0",
"gpu-threads" : "1",
"hotplug" : "5",
"log" : "5",
"no-pool-disable" : true,
"queue" : "1",
"scan-time" : "30",
"scrypt" : true,
"temp-hysteresis" : "3",
"shares" : "0",
"kernel-path" : "/usr/local/bin"
here it is
oh, I can change that, but right now it's just learning to get the thing going, and what fun it is.
I have had to put together two rigs just to get this far!!!!!
cd /
cd /opt/miners/cgminer-opencl
./cgminer -c /opt/miners/cgminer/mining.conf -T
are you running 2 gpu's ? If so add this instead.You can host your wallet on one of the 3 rigs in your sig....
Your .conf file does work, attached below running.
add
"intensity" : "18",
to it though (defaults to 8 with no other parameters set)
Second pic is same config with intensity set to 18
"intensity" : "18,18",
ok try clicking the little terminal box. 2nd box in at bottom left.
type into terminal
Code:cd / cd /opt/miners/cgminer-opencl ./cgminer -T
are you running 2 gpu's ? If so add this instead.Code:"intensity" : "18,18",
