- Nov 13, 2001
- Moderating
Looking really good S_N !
Super Nade said:Sorry to say, mate...you can't really have silent air cooling if you wish to blast a big OC out of your CPU. That is why people move to water.
So,its either of the two. Become stone deaf like me whilst cranking out the GHz or be a wimp and run every component in-spec.
Dragon, we will meet again for sure...only that, you guys would be in the audience clapping, when Tony Dungy lifts the trophy.
PriceKey said:Quick question: though it may sound stupid... but i think it would help the mosfets and pwmic. Should the fan on top of the xp90-c blow away from the cpu or towards the cpu.
PriceKey said:thanks guys, that worked pretty well actually , after putting the fan towards the cpu. (no change in cpu temp, still at 30C(Idle)/39C (full load), but pwmic dropped 10 degrees to 45C and chipset dropped 2 degrees to 46C). Anyway I just restarted the cpu burn in and I'm currently at 280 x 9(multiplier) = 2520mhz at 1.325 Volts! (Stock volt?) (though it says 1.296 on cpuid)
It should be 1.296Volts right? Anyhow thanks! Wow the burn in process does work, thanks.
deathman20 said:Trust bios voltage more then windows voltage. Since you have an ultra-D theres a very good chance its reading 1.325V almost dead on. As for stock volts, mines 1.35 for stock V, its possible that yours is lower only way to know is to check it out with that program thread around here somewhere.
Perhaps DC Opterons are just one of those CPUs the DFI LANPARTY boards likes?dawei213 said:S-N, seems like the combination of both the 165 and DFI LP Ultra-D is key here.
I too hit 2.7ghz (300x9) at right about the same voltage but slightly higher temp (at 54°C) with a borrowed DFI LP U-D board. It was stable through 12 hours of Prime95 on both core. I even ran my RAM at 183mhz divider at 3-4-4-8 with no problem. The DFI board is definitely a good board.
However I have the EPoX 9NPA+. I borrowed the DFI to test the temp. With the EPoX board, I'm currently running 290x9 at 1.55V. From what I've read the EPoX board overvolts a bit as well (and the voltage reading is probably higher than it is).
Nonetheless, the combination of the 165 w/ DFI LP NF4 U-D is the best combo I've seen personally.
IWasHungry said:Perhaps DC Opterons are just one of those CPUs the DFI LANPARTY boards likes?
dawei213 said:Dang, all this testing and I have yet to play any games or do anything else with the computer yet.
