need advice re pci-e cable from Be Quiet Dark Power Pro BBe Quiet QT P7-Pro-650W
mmoalem
Hi all - rehoused my PC interiors into case I was given by a friend. It has a Be Quiet Dark Power Pro BQT P7-Pro-650W PSU but the guy gave it to me lost the PCI-e cables it came with as he did not need them. Unfortunately my Windforce 750 Ti does need a 6pin power... I have looked at various websites but cant make up what cable I need to get - there are various 6 pin to molex or sata that I assume just draw the power designed for HDs. there are 8 pin to 6 pin cables but they are generally marketed as for 8pin cards and more confusing is that the manual I found online suggest that the connector on PSU is a 6pin connector housed in an 8 pin socket...
any ideas for what I should get?
this is a photo of the ports on the PSU: View attachment 196888
