- Dec 17, 2000
- Southern California
I think ive been haning around the forum long enough, and its time for me to venture off and go for my first overclock. I'm going with the KT7 and a duron 600 looking for a great overclock. I can get these 2 for 197 shiped, which is in my budget. I plan on using a PEP66 and doing the simple mod on it to get it to fit. Then I'll do the pencil trick and unlock the multiplyer. Then I'll do the voltage mod which looks a little more complicated but its worth it if I can scrape up a few more volts, more volts should give me a few mhz bonus, and i'm gunna need it in my quest for a gig. I'll also lap the cpu and hsf. I am going to do it very lighty becuase I was told that AMD's chips are very sensiteve and the PEP66 is already pretty well made anyways so its not very necisary. I have a quesstion though, when puting on my PEP66, I should remove the thermal pad then use some good old thermal grease? And i should make the thermal grease as smooth as posible corect? Do I allply the thermal grease to the hsf or the mobo? I put the fan ontop of the cpu itself right? Ugh, I should look at a link, anyone know of one? I dont want to screw this up. . . ;D
