- Nov 22, 2001
- Blacksburg, Virginia, USA
I had a brain fart while reading all this but to my understanding wouldn't there have to be some type of rythem to a processor because of the time a transistor takes to open or close?
it wasn't until WindowsXP was released that the GUI on an intel box became as good as RiscOS
Thingi said:Also is whole point of an Async chip is to remove the central clock because it's becoming increasing difficult to keep the clock in step across the whole processor at increasingly high frequencies. Independant cpu unit clocks is really what were's talking about here instead of true async.
NookieN said:
Due to signal propegation delays, there are pretty advanced compensation mechanisms to prevent clock skew from causing serious problems. I suspect the Athlon has similar mechanisms.
The P4 has at least 4 clocks, which are all derived from the main clock. Even then, the main clock does not synchronize all activity in the chip at one.
Thingi said:Incorrect I'm afraid! The P4 does have double pumping of some of it's units although these units still derive thier clock from the main generator. The main clock in the P4 does synchronize the whole processor.
ninthebin said:I think that what hes getting at is that there isnt 4 seperate clocks working ASYNC from each other - but one clock that controls the rest
