Sold all the items i do not need on Ebay to help with the cost of this build Pierre, got really good price on my old cards and 600T case. I have kept some items back for this build and added a lot of new ones as well. Like the Sapphire 7970 6 GB Card etc, plus others that nobody has seen yet. Sorry to hear about your go slow on your build look forward to seeing that finished too. AJ.
It wont fit, but because that cooler only supports 120mm. Has nothing to do with what type of cooler it is.Peugot to answer you question maybe not because these fans are 140mm size and i think the H110i is a water cooler!
You can mount a 140mm fan on a banana if it had the mounting points! So it doesn't matter what it is, it matters if you can mount it to the item. That said, that cooler doesn't have room for 140mm mounts. So outside of rigging it in someway (double sided tape, zip ties?), it wont work.Well not up to speed yet on the new coolers H110i and the Swiftech one, and thanks ED for the reply to that and the nice Comments. Keep looking in because you have not seen anything yet! AJ.
So to ask the obvious question how are these cards Pierre??? As you should know of all people lol.
wow that is a lot of VRAM for one 24'' monitor...
how do you game on two monitors?
