Hello everyone, I would like to know from someone who owns this case if you can give me an opinion about it, also I would like to ask if it is possible to mount a front 280 mm radiator to it, because the specs on the official website say it doesn't but it supports 2x140 fan (???). I ask this because I run at the moment a custom waterloop with 3 rads (240mm on the front, 120mm on the rear, 280mm on the top) in a mini Itx Manta of the NZXT, but I am not satisfied with the termal performance of my gpu since it reaches even 60 degrees at full load and this even without the front and top panels which I removed to better airflow. Will I get better thermals in your opinion with this? Or you suggest to get the mid tower version?
