Hi, I'm having some problems getting Rosetta to run properly on 1 of my rigs.
It's listed as Rig 1 in my sig. Basically a AMD 620 and 2 GTX 260s.
Boinc will only run 2 apps at once and the other ones are listed as "Waiting for memory". The problem is, BOINC will also pause my CUDA work units while waiting for memory as well.
I've already increased the available memory to 100% while idle or in use, but that didn't help. I've limited the CPU to 50%, which will only run 2 instances of Rosetta, but at least it doesn't stop my CUDA units from running.
I'm running WinXP 32bit and with my 2GB of ram and the 1.79 GB from the GTX260's, I shouldn't be running into any memory limit from the OS. This seems to have started when they started releasing minirosetta 2.00 work that use up 275MB of ram each. But even then, I show >1GB of free memory in task manager, so I'm not sure what's up. The RAC harvest starts in 1 day, so I'm hoping to get this resolved soon if possible.
Thanks
Thanks
