Painting the drive would probably void the warranty.Rob Cork said:Opening your cd drive to get off the faceplate (easy to do, I've done it before) might void your warranty
Hehe, try RMAing it... "I just took it out the box and it wouldn't work - I didn't do anything to it, honest"Crazy Jayhawk said:Painting the drive would probably void the warranty.
Sabre said:I painted a cd and a floppy face plate 15 mins ago (still got paint on my hands ;^) I just stuck a screw driver in the side and they poped off. If you have a slot DVD you will proberly have to pull apart the drive. Oh yeah, if you want to have a painted cd repaced under warranty just clean it up with metho.
