Arkaine23 said:Mine's typically at 60C full load and vcore is reported at 2.05v? I don't exactly trust the sensors on it. XP 1600+ @ 1575
skou said:Mine generally run at 70/85 degrees C. HOT!! They go almost to 85 degrees, before the fan comes on, and will fall back to 75 or so.
They all have run about the same temps, when they are Folding at 100%, so I'm not going to worry about it. Besides, the thermal throttling is working on these, for some reason.
steve
PLOBBY said:I see. Yea i found this program and it lets me adjust when the fan turns on and i set it to 55 degrees C and turn off at 45. It actually cools down relatively(sp) quickly.
skou said:What's the program??
steve
moz_21 said:My XP-M 2600+ runs at 67-70° full load. I found a service manual online and they use thermal pads. Ugh. I will probably use Ceramique in there once my warranty is over in like 2 months. Seems to help, according to some of the laptop articles on OC frontpage.
