0f:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] [1002:731f] (rev ca) (prog-if 00 [VGA controller])
Subsystem: Tul Corporation / PowerColor Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] [148c:2402]
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 94
Region 0: Memory at d0000000 (64-bit, prefetchable) [size=256M]
Region 2: Memory at e0000000 (64-bit, prefetchable) [size=2M]
Region 4: I/O ports at e000
Region 5: Memory at fcd00000 (32-bit, non-prefetchable) [size=512K]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: amdgpu
Kernel modules: amdgpu
12:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] [1002:731f] (rev c1) (prog-if 00 [VGA controller])
Subsystem: Tul Corporation / PowerColor Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] [148c:2398]
Interrupt: pin A routed to IRQ 127
Region 0: Memory at b0000000 (64-bit, prefetchable) [size=256M]
Region 2: Memory at c0000000 (64-bit, prefetchable) [size=2M]
Region 4: I/O ports at d000
Region 5: Memory at fcb00000 (32-bit, non-prefetchable) [size=512K]
Expansion ROM at fcb80000 [disabled] [size=128K]
