FRONTPAGE Noctua Launches NA-FH1 Eight Channel PWM Fan Hub
Noctua has just launched the NA-FH1 eight-channel PWM fan hub. Unlike most fan hubs, the NA-FH1 features circuitry designed to provide a more accurate readout while protecting against overcurrent. The hub works with 4-pin PWN and 3-pin voltage-controlled connectors and has a maximum output of 54 Watts when powered by SATA. The Noctua NA-FH1 PWM fan hub is available on Amazon for $34.90.
Click here to read more!
Good question. I'm not sure of the specifics for this one but I know 54W is the cap for SATA power. I think it's sage to assume it's sage to pull 1A from each connector as that's what MBs do too.
Really this could be a fun experiment. Just someone slamming on the thing.
Like I trust Noctua enough that I'd put an amp through one of their controllers, I'd just want it tested first.
It does list that it has overcurrent protections so I would guess the fans would throttle, either completely off or limited power.
