- Oct 13, 2010
I had written a quick article/question about Intel CPU's but did not post it as I didn't want to sound dumb.
I said that because part of what I wrote is now being scene. Maybe someone else can answer this question.
Why is Jiccman's i7-8700k listed as a Coffee Lake and Johan's i9-9900k listed as a Kaby Lake??? The Kaby Lake was the i7-7xxx series.
MaddMutt / i7-5960x / AIO / 6021
I hope with Colder Weather I can get an extra 100MHz from the AIO
So far the max is ~ 4.825 - 4.850 [16 Cores] or 4.91 - 4.93 [4 Cores]
Drop it to 2 cores and set higher voltage. Or if you have some more time then check which cores are overclocking the best. I don't remember if on your mobo you could pick cores.
Memory looks good already.
You can also check if cache clock will go higher.
I tried too get in on this but I spent so much time trying to get my crappy 2500K past 5.2 that I got too much condensation in the socket....
Nice Metal but you gotta work that RAM
OP updated
My X Hero isn't a Hero when it comes to RAM.
Just picked up a new X Apex that should do better in the RAM department.
