- Aug 15, 2002
Cool Thanx for all the Info...
Maximus Nickus said:Cooling-The Definitive Guide
A great tip to maximise the use of airflow in your case is to do the following:
You will need 1 sheet of see-through glass or plastic the size of your case panel, and 1 incense stick.
Simply replace the side of your case with the sheet of plastic/glass and put the incense stick in front of the PC (not to close…do I smell burning?) and watch the smoke move around your PC, this allows you to see “hot-spots” and other problems with your airflow.
slapshot45 said:great info maximus as i'm reading this sticky for the first time
I'd like to add one bit of info to the above, which is that smoke is VERY BAD for electronics. I don't know about specific kinds of incense but regular cigarette smoke contains among other things small amounts of acid. Over time that smoke will build up a thin layer of 'gunk' on your computer internals and will shorten the life of them. Your case fan will help this process since it draws/pushes more smoke to go through your pc.
A once in awhile test described by maximus above probably won't do any damage, the shortening of life I talk about is far longer than the turnover ratio of people getting newer PC's.
and heck, with faster systems coming out everyday, maybe you'd want an excuse to get that new system...
pour a mixture of Water and a FEW DROPS of Washing up liquid (stops it sticking) onto the paper.
kimbahpnam said:
so what exactly is "Washing up liquid?" is that like just plain hand soap or dishwashing soap or maybe i'm wrong all together...and is it worth it to buy BRASS-O just for a few drops to clean the bottom probably once or twice? or could i do w/o it?
Dr.Octopus said:I have a question regarding the volume of a case in air cooling rigs. I am under the impression that the smaller the volume the better, as the speed of air molecules inside the case would increase (intake and outtake fans remaining the same. This would increase the cooling potential right? For example, a shoebox with and 80mm in and an 80mm out would have higher velocity of air INSIDE the box and say, a refrigerator box with an 80mm in and an 80mm out. By this rationalization, a smaller volume inside is preferable, assuming a decent path for the air, and unrestricted in/out ports right?
thx.
