check build and recommend m.2 drive of OS please
pinky33
So I am building a rig for a friend. Was trying to stay around $500, but I am pretty sure it will be closer to $600 after tax. Friend will get a microcenter CC to get 5% off entire purchase and then pay it all off. I am out of date with SSD's and why some are twice the price, yet seem about the same more or less? Only need a little 250-500GB NVMe for OS. A 1080 GPU from old build will be going with this. If prices for GPU's ever go down a new GPU will be acquired for 1440p gaming.
Assume all other needed parts are coming from old build. Friend definitely wants full ATX size mobo.
Proc: 5600x $ $279.99
https://www.microcenter.com/product...oxed-processor-wraith-stealth-cooler-included
Mobo: MSI B550 MAG Torpedo ATX $149.99
https://www.microcenter.com/product/632831/msi-b550-mag-torpedo-amd-am4-atx-motherboard
If mobo is out of stock then second option is: MSI B550 MPG Gaming Plus $149.99
3rd option: MIS MAG Tomahawk $169.99 ($10 rebate makes it $159.99)
RAM: Thinking the cheapest will be best for the $, but three options.
$61.99 3200 16-18-18-38
https://www.microcenter.com/product...l-desktop-memory-kit-f4-3200c16d-16gvkb-black
$65.99 3600 18-22-22-42
https://www.microcenter.com/product...el-desktop-memory-kit-f4-3600c18d-16gvk-black
$79.99 3600 16-19-19-39
https://www.microcenter.com/product...l-desktop-memory-kit-f4-3600c16d-16gvkc-black
Mobo/proc bundle saves me $20. So after taxes, CC discount I am sitting at ~$492 . Still need M.2 for OS. Can't get much better for around $500 I think. Last time I went to microcenter they were out of half the stuff on the list because what is going on these days. I had to get more expensive ram and the two cheaper mobo's says 2 in stock and 1 in stock. So who knows.
Thank you.
-Pinky
pretty much any nvme will do and perform about the same , if you must have an nvme drive.
very basic rules of thumb for nvme drives, bigger is better, name brand is often the safer bet.
To me, after booting A sata ssd drive gives the same experience but nvme is more blingy.
get the 500 gig.
WD is fine, I run 2 1TB wd's in my game rig.
that opens to the duluth store, where are you?
Will you be putting this m.2 NVME in the i7-2600k rig in your sig? If so, better check the motherboard specs to see if it will work with a PCI-e bus m.2 as opposed to a SATA-based m.2. That's an old board from a time when there may not have been support for NVME/PCI-e drive technology.
And make sure it has TLC memory not QLC. And having a DRAM cache is good to have as well.
I used to live there, I have moved to the islands, ST. Lucia to be exact.
I still own A house and some property there, out side Gainesville, out Clarks bridge road, I still prefer US doctors so we go there quite frequently.
