- Dec 7, 2003
- Thread Starter
- #61
Thanks!
Final Assembly
First I attached my 4 posts to the bottom panel.
Each L bracket attaches to panel with 2 screws. So I fit the post to the panel side,making sure everything is nice and square, and mark my holes with a pencil onto the surface of the aluminum trim piece underneath. Then I center punch the holes, drill them with my #36 drill bit, threw the aluminum trim and then down into the MDF panel underneath, to about the depth of ¾”. Then I tap out the holes.
Each post has 8 mounting points to the panels, so this process get repeated 32 times!
Got the bottom panel attached:
Attached the top panel.
Mounted the PCI bracket.
Mounted the power supply bracket:
Mounted the radiator bracket:
And any other brackets such as the Brollocks fan bracket:
Somewhere along the way, also added black plastic end caps:
McMaster Carr web link:
https://www.mcmaster.com/#92675k43/=19txbqw
When I’m adding the plastic caps, I know I’m pretty much finished!
Final Assembly
