Whats the recommeded/minimum core voltage for a tbird 900? When I looked in the bios this was set at default which was1.82v, which in turn meant that temps were 54C idle and 59C loaded. The lowest voltage at which I can complete boot is 1.69V.
Also, I had been running one PC133 64mb dimm with one PC100 64mb dimm (presumably both at the lower speed) until I swapped the PC100 for another PC133 64mb dimm. However I had to up the ram voltage from 3.3v to 3.6v to be able to boot completely with the ram set to 133mhz, anything lower led to continual registry errors. With the ram set to 100mhz, I can boot as normal at 3.3v. Is this normal and or safe? Also, I can run both dimms individually at 133mhz, 3.3v with no problems.
My mobo is a Soltek 75-kv+. Any advide would be greatly appreciated.
Squeaker
Squeaker
