- Dec 6, 2010
1. cpu juice port
2. forgetful slots when powered off
3. motherboard juice port
4. short rectangle slot
5. long rectangle slot
6. old rectangle slot
7. heat dissipation square
8. fast 5 dimension accessory plug
9. old disk ports
10. some IC's that do stuff
11. slow 5 dimension accessory plug
12. where the 200lb gorilla meets the machine
My turn.
1.cpu socket
2.ram slits
3.power connector from power supply
4.pci Express 1x(I cheated, it says on the board and I looked)
5.pci ex16
6.pci port
7.gigabyte eye
8.
Ok, I stop, it says on the board most hard things.
1. cpu juice port
9. old disk ports
10.some IC's that do stuffedit: chips that forget stuff when you remove their battery.
I ate and now have strength to continue.
8. USB 3.0 connector for front panel on the case
9. Satan ports
10. Bios chips, I actually remember what they look like from someone posting them in other thread
11. Regular usb connector for front panel on the case
12.pins for resenting bad overclocks or enabling higher oc voltages stuff
Oh missed 3. It's a small tax connector.
I was scrolling on phone up and dwn to see photo and type. Autocorrect took care of rest.
Wagex, I have SSD on sata btw. Crucial m4 128gb. Plenty of space! Always have like half empty
for what its worth... sata is old disk ports, its 2019 usbc and m.2 / pcie are new.
The RTC was introduced to PC compatibles by the IBM PC/AT in 1984, which used a Motorola MC146818 RTC. Later, Dallas Semiconductor made compatible RTCs, which were often used in older personal computers, and are easily found on motherboards because of their distinctive black battery cap and silkscreened logo.
In newer systems, the RTC is integrated into the Southbridge chip.
This is a test of your motherboard component identification skills, identify each numbered item in your reply with the number and name of each item.
The manufacturers really play a game of carrot on a stick with consumers.
