- Jul 16, 2001
- Scotland - And don't you forget it!
It's been muttered in Cooling about the different SHC's of metals and its effect on the performance of heatsinks.
As you are probably aware, the specific heat capacity of a solid or liquid is defined as the heat required to raise unit mass of substance by one degree of temperature. This can be stated by the following equation: ∆Q=mc∆T, where ∆Q is the heat applied to the substance, m=mass of substance, c = Specific Heat Capacity, and ∆T the rise in temperature.
As ∆T is the factor we (as overclockers) are interested in keeping as low as possible for a given heat output (the burny, burny CPU), there are two possible options for improving performance of our heatsink. Either increase the mass, which leads to motherboard stress etc etc, or use materials with a higher Specific Heat Capacity.
If we take Copper as a standard base material, we can compare its SHC to that of other materials. Here is a link to a periodic table with regard to SHC.
Why do we stick with Copper? There are many more materials with better properties. Nickel and Iron both have higher SHC's and would (technically) make better heatsinks.
One reason is Thermal Conductivity. Although there are materials which have more suitable SHC's than Copper, Only Silver is actually able to transfer heat at a faster rate than Copper. In descending order:- Silver, Copper, Gold, Aluminium,Berrylium, Calcium, Tungsten,Magnesium, Rhodium and Iridium have the best Thermal Conductivity.
Have metal heatsinks had their day? Is exotic liquid cooling the way forward?
Or should we start looking at special cooling alloys to get the best out of our heatsinks?
