Today I try to finish ITX Skylake-X build. Most of these components were used in other builds, were review samples or I simply keep them for some time and don't really want to sell. It will be probably my brother's PC soon but have to finish it.
General specs:
- i9-7900X - capable of 4.7GHz but I guess in this small build it won't run high because this CPU generated a lot of heat
- ASRock X299E-ITX/ac
- 32GB DDR4-2666 Crucial SODIMM ( capable of 4000 stable )
- EVGA GTX1070 FE
- Phanteks Enthoo Evolv ITX
- Enermax Platimax D.F. 750W 80+ Plat.
- 240GB Patriot Hellfire NVMe SSD + 480GB Crucial BX300 SSD ( there are 2 more M.2 sockets free so maybe will be some more drives in some time )
Custom water cooling - most from Alphacool:
- Eisblock Nylon Clear
- NexXxos GPX for GTX1070
- NexXxos 280mm copper radiator
- AquaTuning UV-Crystal blue coolant
- Aurora UV hardtube LED rings - somehow they fit perfectly on flexible tubes
- XSPC pump/rad, just because I couldn't find anything that won't interfere with other components and cables and wouldn't be too high cost
I will try to add some more photos in time.
General specs:
- EVGA GTX1070 FE
