- Jan 4, 2024
- Indiana
How good would 3X MSI GeForce GT 1030 DirectX 12 GPU'S to Fold@Home? Like points speed they would get done etc.....
That sounds great cause I am only going to put $600 into a folding rig.Each GT 1030 will get you about 100k PPD using Windows. Linux is a little worse at 97k PPD on average. So 3 of them running Windows can get you about 300,000 PPD.
GeForce GT 1030 Folding@Home PPD Averages, Power Consumption & Research Projects
F@H GeForce GT 1030 performance as of 5/1/2024. Averages across all projects PPD:103,082 - Work Units Per Day:1.01, performance history and more.folding.lar.systems
What precipitated the change?I have decided to get 3 1050 tis to fold with.
Curious...is your goal just to play with a cheap F@H system or get the most PPD? You're doing the former, but if you're after the most PPD for your dollar, you should buy a ~$600 video card instead. Also, from previous threads, you mentioned that your existing system would be for F@H?? Confused by the waffling.
Just making sure you're on the right track for whatever you want to accomplish (which is...............???).
....you didn't manage to answer the question.The 3 cards on $389.And they will have good PPD.
Trust me, we know!I am also in the prosses of building my new gamming rig.
0-2 in answering the question straight up, lol. Just confirming... this is your way of saying you want the most PPD for your dollar, right?So what is a good example of a $400 card that is Nivida.
No clue where you got that info from. According to the chart above, a 4060 Ti is ~6-7M. I can tell you with mine (W11), it was around 7M for my day of testing before the upcoming challenge.Will get 4,191,526 PPD.
We've posted this in a couple of your threads already (including this one)...use this link as a resource for PPD and PPD /KW.
GPU Folding@Home PPD Overall Ranks Database
folding.lar.systems
Simply search on the page for the card (I typed in 1030 and 1050) and see where it lands.
No clue where you got that info from. According to the chart above, a 4060 Ti is ~5-7M. I can tell you with mine (W11), it was around 7M for my day of testing before the upcoming challenge.
It seems to get more PPD in Linix.We've posted this in a couple of your threads already (including this one)...use this link as a resource for PPD and PPD /KW.
folding.lar.systems
Most (All?) cards get more PPD in Linux....................you know that (and presumably why you were trying to get Linux working in the recent past).It seems to get more PPD in Linix.
.....sell it? Sell both and get one more efficient card for the money to pair with the 4060 ti? Build another PC? Donate to a friend in need? Whatever the hell you want! Not up to us.I just got a idea. What if the folding rig that I have right now I take out 1 of the 1080 tis and replace it with eather the 4060 or 4060 ti but what do I do with the other 1080 ti??
