- Apr 30, 2006
- United States
I know this sounds silly but I can't remember my internet password. I'm on win11 and my brain went stupid-er. Our provider is Comcast, could you please walk me through the steps to the settings?
Are you asking for your SSID password? Is it something that you set or use one that your ISP provides for you? Are you using your own router or one that Comcast provides?I know this sounds silly but I can't remember my internet password. I'm on win11 and my brain went stupid-er. Our provider is Comcast, could you please walk me through the steps to the settings?
Check on the router/access point itself. Some ISPs will put the SSID and password on a label.I'm sorry if I'm not asking the right questions, my brain has turned to since the cancer last year. I want to know where on my computer I can find the wifi PW. We are using the Comcast router. We changed the pw when we were set up in our new house. I'm sure it's the same p/w we used to set up the wifi printers. I've gone to network & internet but didn't find anything,I feel soooo stupid. I don't want to reset it because I would have to change it on everything else. There is a location in the setting somewhere with this info right?
When you go to 10.0.0.1 and log into your modem/gateway you can see your current WiFi password. However, you can't change it there because Comcast locks your settings. To change your SSID or WiFi password you have to use the Xfinity app on your phone.Your Wi-Fi password is configured in your router. You can access a Comcast router in your browser by going to 10.0.0.1 and adjusting it from there.
Maybe this helps? It should navigate you to the place where it is/you can see it...
Change Your WiFi Network Name and Password With the Admin Tool
Learn how to use the admin tool and change your WiFi network name and password.www.xfinity.com
