Help overclocking 2x16gb G.Skill 6000MHz CL30 on 7800x3d
teodenetto
Overclocking 2x16gb G.Skill 6000MHz CL30 on 7800x3d
Hello guys, I have this set of ram F5-6000J3040F16GX2-TZ5RK paired with 7800x3D and a X670E Aorus Master. I want to overclock and lower the timings on this kit of ram. Is it possible to make they running at 6400MHz at CL30? The CPU is stable with PBO Curve Optimizer -25 and +200. Tested with Linkpack Xtreme and no crash. Max temp 75. I leave the standard timings of this ram. Thanks to people who will help me!
Set main timings like in the XMP/EXPO, but manually 6400 memory clock and 1.43V VDD/VDDQ ... and find out.
If it won't work then:
1. the motherboard has a limit of 1.43V VDD/VDDQ, and memory may need some more for CL30 - then run it at CL32 as the performance is almost the same
2. the memory controller can't handle it at 1:1 - then try 6200 CL30 or even CL28
