- Dec 9, 2002
We will only enable payouts after we are sure everything is OK.
We hope to have them enabled in the next 24 hours, once we finish rewriting some of the code.
At my last post, payouts were supposed to be re-enabled - the message at the time stated it would take 3 hours, and I had read that in the morning yesterday.
At some point they updated that post, clarifying:
So its 24 hours later than the first message, payouts still disabled. Fortunately it indicates they are being diligent even at the cost of their previous announcements.
EDIT: Also, the last difficulty change for LTC was -21%. The estimated next difficulty change is -16% but its 3 days off so that is likely to change a lot before difficulty actually adjusts. Even with the drop in value and in the LTC network hash rate, its more profitable now than the past couple weeks to mine LTC - just still less profitable than it is doing doge right now.
Pool Payouts: Manual and Automatic
serrazserraz 1:59PM
We have started to test some new code for auto and manual payouts which will add soem extra security. I will post some details below and update this thread with new information.
Some of the new security that ha been put in place are as follows:
From now on when a SQL injection attempt is detected rather then just dropping the query the system will auto lock (maybe delete) the account that its originating from. When this code was tested 2 accounts were locked instantly trying to Preform attacks.
This option may need some rethinking which is where we will ask you all at a later point. When a address is changed on any coin all payout addresses will be locked untill myself or khaos unlock them. This will stop help anything like this from happening again
I know you are all getting fustrated either waiting for your coins to get recredited or waiting to get your coins out of the pool but as you can see from my first point if we rush it and enable payouts and things go wrong then what is the point of making changed at all.
serraz Also some great news jsut tested new withdrawal and address update code on BTC as i had a blance there. Worked perfectly so we will start to move it to teh other coins.
FTC is being done right now once that is done and we confirm a large number went ok then we will enable it on LTC as i expect there will be a massive ammoutn of traffic
Yeah, I thought they fixed the problem, but I still can't cashout my LTC.... might be a while...
17:12:31
serraz
ok
17:12:35
serraz
all payouts are activated
17:12:48
serraz
you all need to set your payment addresses and thresholds on all pools again
My account paid out normally.
Remember folks, pool =/= bank.
Yes, know when did they say they would replace the stolen funds?
Looks like I'm still out 0.3 LTC
