Meh. I thought you always had to do that.
I'm not sure if this is related to the mentioned issue but I'm not able to edit my older posts/threads while I can edit my new posts (from 1-2 days ago). In short, I wanted to add something to my memory list and there is no edit button.
You had to for attachments, but not for just images. IMHO most times you're dealing with images in posts you should probably be in Go Advanced anyway.
It was something unrelated, but you should be good to go now.
This is alien language to taco. But thank you!
added the data to this one.This is what the above codes would produce.
This one is broke now.
data1 | data2
data3 | data4
It was much easier than...
data1 data2 data3 data4
EDIT!!!! I just noticed the New Table icon in advanced! Click a few radio buttons and spits this out. usable possibly
