At the risk of a long, drawn-out conversation....why? You hadn't mentioned poor coverage of Wi-Fi...................
.... haven't used the integrated Wi-Fi on your new board to see if it's sufficient
.... haven't tested the Wi-Fi card you're buying 'for BT' (for no reason) to see if it's sufficient
It feels like you buy new **** without even knowing if what you're going to have works. At least test out the integrated Wi-Fi first...THEN buy the Wi-Fi card (for BT - even though it won't help) and see if that helps your Wi-Fi range.
Also, I don't know how the antennas work, but, the included antenna uses both ports... I'm not sure how either device would work with only connecting to one.
