- Apr 28, 2008
- Melb, AUS
hi all,
i've got a 4850 which has been dodgy for me. the story is, i can't run my card at 700/1000 anymore. everytime i run a modern game (cod4, crysis, prostreet, undercover etc. ) my screen would freeze for one second, then come back to normal, then repeat itself over and over. i would ctrl alt delete, then in the task bar, there was an Event Viewer which stated my display has just recovered from an error or something. (i can upload screenshots if you need)
thinking back, the changes relating to my 4850 i've made is updating drivers and changing the PCI E frequency in BIOS. 700/1000 ran fine on 8.10 drviers, and i believe my PCI E freq. was set at 110mhz (didn't realise it). when i did realise this, i set it back to 100mhz. since then, my card has been sitting at a sad 650/950 - stock.
just wondering if the PCI-E freq. setting can make that much of a diff, or is it the drivers, even though drivers are meant to ADVANCE the performance of a gpu.
i'm just a bit confused atm, so any help would be greatly appreciated.
thankss!
thankss!
