- Feb 25, 2004
- N of splat W of Torin
Something that might work on an armchair...and it's for gaming. Maybe $50 or so...
I have one right at arms reach but I am trying to get away from anything not USB C...The Logitech I mentioned comes with an A to semi-custom micro cable. Worst case you can get a C to A adapter for it.
I use a game controller (PS 4) for golf ....and maybe you folks can tell me, do all mice have the scroll wheel tilt to either side as a function...BG3 specifically uses that for camera movement.Feels like overkill, but has all the specs at least. 25.6k DPI is a bit insane, lol.
Can't help out too much here.... my keyboard (specifically the "u" key) quit working so I got this $30 wireless k/b and mouse combo. It played golf fine... but was small in my hand for PUBG/FPS. Not for gaming, really.... I'd say the antithesis of what you just posted, even. LOL
I've never owned a mouse that had a tilting wheel.I use a game controller (PS 4) for golf ....and maybe you folks can tell me, do all mice have the scroll wheel tilt to either side as a function...BG3 specifically uses that for camera movement.
The newer MSI GM51 uses USB-C. The previous Gen GM41 uses micro-USB.I guess I needed one that works on any surface so that is why I designated it as a laptop mouse. I do have a flexible mouse pad to use on the arm of my chair.
Can I charge both the MSI and Logitech with USB C ? I can't see the port. I have 2 USB C's charge cables at my chair. 1 45W laptop and one PD or phone charger. It is important that it not be USB A.
I would have been good with that I never found it in the spec or pic.The newer MSI GM51 uses USB-C. The previous Gen GM41 uses micro-USB.
EDIT: It also comes with a charging base.
Yeah I was about to return cuz I didn't notice it didn't have Bluetooth.... Yet the little connector plug stores inside the bottom. So it's easy to unplug it and stick it in a different computer.That IS a pricey mouse, sheesh! Glad you like it!!
