- Aug 18, 2001
- Medicine Hat, Alberta, Canada
Ok, here are my power related questions.
1) My 5V line sits at around 4.87V does not change voltages. The odd time I see it at 4.88 or 4.89 Is this actually all that bad.
2) As I add fans etc.. to my case will this drop off even more even if I run them off the 12V lines?
3) My VCore Voltages shown through CPUCool tends to fluctuate between 1.79 and 1.81 Volts. Now my bios is set to 1.75V Could this be a problem with my power supply?
I was originally told it was my mobo that was pushing the VCore Voltages higher.
4) Is the above Vcore fluctuation bad for my system?
I have a 300W Antec PSU not to sure what model. And I'm running a 1.4 on an A7A266 Mobo.
Any Replies are very welcome as, I want to replace this PSU ASAP if it's actually to blame. If it's bad I got a funny idea about what killed my last mobo and CPU!
Thanks fella's.
PS: Would the increased voltages also be part of the temp issued I'm having?? I have a Volcano6CU+ and even at default 1.4 my CPU temps under load never go below 49oC and that's with ambient temps of no higher then 24oC in my house generally cooler right now!
Thanks fella's.
