Pro players seem to swear by 24" monitors so they have less eye and head movement for peripheral view. 32" I would need to move screen further backI game mostly FPS on a 28" 2560x1440 monitor at arm's length. If I were to go 4k/120 it would be 32". Otherwise windows is too small ulto use the space, IMO.
I dont know about an optimal size for fps tho....that has to vary by user and situation.
I checked the links, and I had no trouble.I can't view those links as Amazon's site tries to be smart and shows me something totally different on my local site.
That aside, a higher resolution display will be higher resolution so you get more details. I find 1080p a bit blurry after using a 4k TV to game. Just hope you have a nice GPU to go with it.
They know I'm in the UK and want to show me UK things instead. I can see from the URL that what they're showing isn't what you linked.I checked the links, and I had no trouble.
Oh ok.They know I'm in the UK and want to show me UK things instead. I can see from the URL that what they're showing isn't what you linked.
How do you feel about the PPI for that 32"?My gaming computer is a 32" 1440p monitor on a larger desk that is roughly 32" from my eyes,
After upgrading from 24" 1080p (same PPI as 32" 2560x1440) to 27" 2560x1440, I can't lower my PPI...I can see the pixels from arm's length (a bit over 26"), lol.
