The RBT Rebel Real 1.112 Mouse Review
The RBT (Right ‘Bove Touch) Rebel Real mouse is new to the market from a new company by the name of QuadraClicks Gaming, located in Los Angeles, California. They have gotten their start through an Indiegogo crowdfunding campaign and have been successful in getting their design manufactured and ready for public consumption. As a fledgling company, they’re still in the process of establishing the basics such as a website while currently relying on their Indiegogo page for information.
Their goal was to design a new mouse which helps eliminate some of the physical issues associated with using a PC mouse for extended periods time at work or play. Common issues associated with extended usage range from arthritis in the fingers, Carpal Tunnel of the wrist, and repetitive strain injuries (RSI) of the neck and shoulder even headaches can be attributed to extended mouse usage.
RBT Rebel courtesy of QuadrClicks Gaming
To accomplish this, the team at QuadraClicks Gaming took a differing approach to hand placement and how you interact with the main buttons of the mouse. The main buttons on the RBT “Rabbit” have been moved up more to the top of the mouse like ears as the creators describe them. This does give the RBT a very unconventional appearance, but the idea was to take the pressure off the fingers tips and distribute it along the length of the finger. This approach also changes the muscle groups which are used, moving them away from the hand and into the arm. According to the QuadraClicks crew, this should eliminate RSI related to mouse usage and also improve accuracy and reduce reaction time.
Specifications and Features
Including the Pixart 3336 optical sensor and 250 IPS with 50 G acceleration gives the RBT Rebel the advantages of a gaming mouse with great tracking abilities. Combine that with the downloadable software that allows customized settings for polling rates, DPI, and the six programmable buttons the RBT can be finely tuned for every situation. Full specifications are listed below.
QuadraClicks RBT Rebel Real 1.112 Specifications
Mouse Type Optical, Right Handed
Optical SensorPixart PWM 3336
Rated DPI500/1000/2000/4000/6000/10700 DPI fully customizable
Polling Rate250/500/750/1000 Hz polling rates
Number of Buttons6 programmable buttons plus LED ON/OFF switch
Movement250 IPS with 50 G acceleration
ConnectivityUSB Type-A, 1.8 M braided cable
Weight140 g
Dimensions114 mm x 64 mm x 44 mm
Warranty1-year limited, exchange only
Packaging
The RBT Rebel arrived in a plain cardboard box for shipping. Inside was a black box wrapped in bubble wrap for protection during transport. The packaging itself doesn’t have many particulars about the mouse such as specifications. The front has a line drawing of the mouse with the RBT logo and aside from a couple of ad-like sayings it’s quite plain. Turning it over reveals the serial number and address for QuadraClicks.
Once inside you can see the RBT Rebel is very well packed in a foam cutout with separate pockets for the main unit and the cable. Removing the mouse and foam we find a small leaflet detailing the button functions and locations. The Rebel does have some proprietary software, this leaflet would have been a good place to include a download link. I will add this link to the review in the software section later on.
A Closer Look
The first thing you’ll notice about the RBT Rebel Real is it’s not your typical optical mouse. The main left and right buttons are raised off of the main body which gives them the appearance of “ears”. I have to wonder if that’s why there’s a rabbit in their logo. QuadraClicks does use the term “rabbit” in some of their writings, but usually as a replacement for RBT. The mouse also includes your typical click/scroll wheel and directly behind that you’ll find your DPI switch for mouse sensitivity. They have also included two buttons on the “thumb” side of the mouse, and finally moving to the bottom you’ll find a switch to turn the LED of and on which illuminates the RBT logo.
Software
The QuadraClicks software allows for fully customizing your RBT mouse to best suit your needs and the ability to save your custom profiles for easy access. Each button is programmable and it also includes a macro feature for complicated moves. The DPI button has six positions which can also be user defined with custom settings and LED color coding so you know with a glance which setting you’re using. Initially, I did find the LED section a bit awkward trying to set a static color but soon figured out it was connected to the DPI switch. The software itself is a nice small package and quite easy to use opening up nearly limitless possibilities for custom tuning your RBT mouse exactly the way you like it. Here’s a direct download link to the software.
Final Thoughts
Using the RBT Rebel was a bit awkward at first and did take some time to grow accustomed to. The shape and position are quite different from a conventional mouse but that was to be expected as the idea behind it is to help eliminate some physical symptoms and even injuries that go along with extended use of a PC. This is what attracted me to the RBT in the first place.
Without going into too much detail, I have spent the better part of the last 15 years perched at a desk behind a PC eight hours a day for work, plus my extracurricular activities which also revolve around a PC. This has taken a bit of a toll on my right side which always seems to have a mouse in hand and has caused some physical symptoms that have grown to be quite uncomfortable over the last few years.
After using the RBT Rebel in place of my standard DELL mouse at work for the course of a week it actually grew on me. The ironic part is I didn’t realize how much it was helping until I forgot it at home the following Monday. Within the first hour of using the DELL mouse the numbness was creeping back into my first two fingers, and by the end of the day, I had that all too familiar headache. I can’t say this mouse is a cure for anything, but it really did help me.
The RBT Rebel Real can be found on Amazon for $88.88 plus $4.99 shipping which is a bit pricey for a mouse compared to some high-quality gaming mice on the market these days. After using it for over a week and knowing what I know now, to me that’s a small price to pay for the relief I feel from it. I can honestly say it has worked for me and would recommend it to anyone who has similar issues caused by extended PC use. Overclockers Approved!
Click to find out what this means
-Shawn Jennings (Johan45)
Loading new replies...
W
Woomack
Benching Team Leader
13,193 messages 2,216 likes
Interesting review :)
Reply Like
Avatar of Johan45
Johan45
18,290 messages 167 likes
Quadraclicks has offered a $10 discount to OCF members in NA, just waiting on more info from the owners
OK I have the link for the discount for anyone interested in giving the RBT a try.
RBT Mouse Discount Order Page
Reply Like
Avatar of CyberianIce
CyberianIce
19 messages 0 likes
Ugly as hell
This is so ugly. Single picture explained everything.
Reply Like
Avatar of Johan45
Johan45
Looks aren't everything. I'm still using it daily
Reply Like
W
Woomack
Most mice are ugly and still when you use it, you can't really see it :) In this mouse what is important is that your hand won't hurt after long hours of work. I wasn't using it but looks like it helps.
For me it's only about 12 macro buttons too few ;)
Reply Like
CyberianIce
19 messages 0 likes
Looks isn't everything - agree. But this mouse specs/performances are inferior compared to my 3 years old Mamba TE. I still doubt this can be ergonomically efficient as Logitech MX.
Reply Like
W
Woomack
No one said that this mouse is for gamers. I guess it's more for general use. I won't say much as I was only reading/hearing some comments from users. Looks meh but seems like it works good.
For me Logitech MX is not comfortable. Actually barely any mouse is good for me. I'm using Corsair Scimitar only because of many buttons with shortcuts for mmo games. It's not perfect but somehow I got used to it.
I'm surprised that your Mamba is still working after 3 years ... personally, I don't know anyone who had working razer mouse after 2 years. Maybe it's just my experience ;)
Reply Like
Avatar of Johan45
Johan45
I have never tried that logitech mouse but it functions the same way as any conventinal mouse using the finger tips for button activation. This one doesn't my left click is made using that lower meaty part (proximal phalanx) of the index finger. I acually have feeling in that finger tip again which after a day at work I didn't with the old DELL mouse. It has also alleviated the headache I would get some days from the tension in the right side of my neck. I also have no issues gaming with it. No I'm not a "hardcore" gamer but do like FPS like DOOM where you never stop shooting.
Reply Like
CyberianIce
19 messages 0 likes
Logitech MX Master 2S is proof that no ambidextrous mouse can NOT be ergonomic at the same time. If it's ergonomically designed - it must have different design for left and right handed users, unlike this creepy thing from the title
Reply Like
Avatar of Johan45
Johan45
I get it you don't like the looks, that doesn't mean that the RBT isn't a good mouse that does what it claims to do.
Reply Like
